How disable sleep mode on RoomKit Plus codec ?
kost@ngs.ru
Hi.
How can I make RoomKit Plus codec not switched to the sleep mode.
(the codec must remain active no matter what).
tomas_vll
I dont think one can disable standby perminently. The timer can be set 0 to 480 minutes i belive (default 10). If you recuire mor the 6 hours of non standby There is a way which might work: write a macro that listens for the standby state to change, if its changed set the standby to off (= not in standby mode). I have used the same kind of trick to block incomming calls, since one can only block a incomeing call a certin time.
If you upload a Custom Wallpaper to the unit. it disables many things, and I think the sleep mode is one of these.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Thanks @Wayne DeNardi
That helped why the device was not showing the home screen (Upcoming Meetings).
Once turned off the custom wallpaper, it started showing the upcoming meetings.
The end users were assuming that the wallpaper was actually -> "Standby Mode"!
Whereas its only in Idle Mode with the wallpaper.
