06-17-2004 08:08 AM - edited 03-17-2019 08:13 PM
I have a 10MB data ATM PVC configured thru the DS3 interface:
interface ATM2/0
no ip address
ip route-cache flow
no atm clock INTERNAL
atm pvc 2 0 16 ilmi
no atm ilmi-keepalive
interface ATM2/0.1 point-to-point
ip address 164.72.47.129 255.255.255.128
pvc 18/18
class-vc VBR-NRT
vbr-nrt 10000 10000 100
encapsulation aal5snap
..... and have found out that this interface does not support CBWFQing - so I can't configure standard LLQ priority for video QoS.
This PVC is getting very congested and we are experienced poor video conferencing sessions.
What can I do since LLQ/class-based QoS is not an option?
06-23-2004 12:50 PM
Why your ATM interface does not support LLQ/CBWFQ?
I hope your interface suppoprts AutoQoS.
Please go through the following link...
http://www.cisco.com/en/US/tech/tk543/tk759/technologies_q_and_a_item09186a0080134a66.shtml
08-03-2004 12:16 AM
A good starting point for you would be to change from VBR-NRT to VBR-RT, nrt and rt stand for non-real-time and real-time. This sets a tag in the ATM header and allows the telco switches to give some kind of priority to the real-time traffic, Although this may well depend on the service contract you have with your Telco.
08-10-2004 07:50 AM
Please excuse my ignorance but is this module fitted to a router? If so you'll have to run one of the T train IOSs, create a virtual interface if you intend on running rtp compression. You will probably have to apply the service-policy directly to the PVC.
Applying QoS to ATM circuits can be tricky. Here's one I've just installed. Pick through it feel free to use it if you want to
class-map match-all voice-bearer-atm
match dscp ef
class-map match-any voice-signaling-in
match access-group 101
class-map match-any voice-bearer-out
match ip dscp ef
description match for signaling traffic
match ip dscp af31
description match for voice bearer traffic
match ip rtp 16384 16383
class-map match-all voice-signaling-atm
match ip dscp af31
policy-map voice-atm-egress
class voice-bearer-atm
priority 1300
class voice-signaling-atm
bandwidth 150
random-detect dscp-based
random-detect dscp 26 80 120
random-detect dscp 34 80 120
interface ATM3/0.18 point-to-point
description *** xxxxxx ***
bandwidth 2000
pvc xxxxx 1/33
vbr-rt 1920 1920 200
inarp 10
tx-ring-limit 3
oam-pvc manage
oam retry 3 3 3
encapsulation aal5ciscoppp Virtual-Template1
max-reserved-bandwidth 80
service-policy output voice-atm-egress
interface Virtual-Template1
ip address 10.x.x.x 255.255.255.252
ip tcp header-compression iphc-format
ip rtp header-compression iphc-format
access-list 101 permit tcp 10.x.x.0 0.0.0.255 10.x.x.0 0.0.0.255 eq 1720
access-list 101 permit udp 10.x.x.0 0.0.0.255 10.x.x.0 0.0.0.255 eq 1719
access-list 101 permit tcp 10.x.x.0 0.0.0.255 eq 1169 10.x.x.0 0.0.0.255
