how does one use the manual focus feature in Cisco c40?
graham.davidson
Community Member
                  question as above? Can you manually focus the camera using the remote control?
mubakhta
Level 9
Level 9
Hi Graham,
I believe it is not possible using the remote control. However, you can use the API on the codec to focus. Here are the commands to perform the procedure:
xCommand Camera PositionSet
    CameraId(r): <1..7>
    Pan: <-65535..65535>
    Tilt: <-65535..65535>
    Zoom: <0..65535>
    Focus: <0..65535>
Hope this helps.
Mubashshir Akhtar
Thanks Mubashshir Akhtar
thanks Mubashshir, I thought that might be the case as I could not find any way of doing it, seems like a bit of a pointless feature as you would need to be in front of the system to check the focus anyway.
Graham,
I couldn't agree more. I believe this feature should be available on TC 6. If not, then you can maybe work with your Accounts Manager and open a feature request.
Mubashshir Akhtar
