How many monitors will a presentation codec support?
How many monitors can a presentation codec support?
Justin Ferello
Level 5
Level 5
Adrian,
I am not sure what a 'presentation codec' is exactly but I can speak on behalf of the ex-TANDBERG codecs.
The EX90, C20 & C40 all support (2) screens with an optional key purchase.
The EX60 only supports (1) screen.
The Edge 75/95, 3000, 6000 MXP & C60 all support (2) screens natively.
Finally the C90 supports up to (4) screens natively.
Justin
Thank you,
Justin Ferello
Technical Support Specialist, ScanSource KBZ
Failed to mention the system didn't I. We are adding a presentation codec to a Cisco 1300.
You'll need to use an HDMI splitter to get two or more external displays. The AV
expansion box has this capability, but in the 1300 HDMI ports are used for the
left and right camera. You'll need to order another AV expansion box or just use a supported 3rd party
HDMI splitter
