How to add TCS to TMS in Active Directory
Hi all,
I'm trying to add a TCS to a TMS as a recording device but it ends up with an error "Wrong username or password".
Both of TCS and TMS belong to a same AD (test.local), so I tried "domain/username" and "password", "username@domain" and "password", or simply "username" and "password", but none of them worked.
Of course, I have already confirmed admin account of HTTP for the TCS is valid.
Do I need any configuration change or something to add the TCS?
  TMS Version: 14.5.0
  TCS v6.1
Kotaro
Hello Kotaro
The TMS uses API TCS account, not Windows.
You need login in TCS Configuration>Site Settings> API > change password for API
br Oleksandr
Hello Kotaro
br Oleksandr
Hi Oleksandr,
Thank you for your information.
It works fine!
Спасибі!
Kotaro
Thanks Dears, i was having the same problem and solved by changing the above mentioned Configuration.
Abed
Patrick Sparkman
In addition to what Oleksandr has already mentioned, it's in the TCS Admin Guide on how to add TCS into TMS as a recording device.
