04-12-2016 10:37 PM - edited 03-18-2019 05:48 AM
Looking to this Topology Please Help me how can i Configure SX 20.
Solved! Go to Solution.
04-12-2016 11:30 PM
If you do a search in these forums for SX20 Standalone, you will see a whole bunch of posts that describe how to configure a SX20 and the firewall ports required.
One good example is this one: SX20 Standalone
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
04-12-2016 11:30 PM
Wayne
06-16-2016 09:32 AM
Is it possible to schedule a reboot of SX 20?
Thank you,
Steven
06-16-2016 11:41 AM
There is no way to schedule a restart with the just codec, as it doesn't have the capability to do it on it's own.
If you have TMS in your environment, you can setup a persistent configuration template to restart the SX20.
If you do not have TMS, then you can use a 3rd-party application to connect to the SX20 via telnet or SSH and use the following API command based on the software type the codec is running:
The only other option would to periodically connect to the codec manually and restart the codec using the API or through the web interface.
