How to make a call using ip address
Zhomart Asken
Hi! I'm very new to Telepresence system and wanted to know about making calls from one endpoint (f.e. MX300) to another (f.e SX20) using their ip addresses(public or private). I have seen in the config guide that they make calls through IDs or URIs and they need gatekeeper/SIP proxy for that, but how can we establish connection through their ip addresses without extra devices, just endpoints?
2 Accepted Solutions
sagsheth
Hi Zhomart,
I presume you want to directly(without using gatekeeper) call other endpoints using IP addresses.
This is very simple.
Use remote control and punch in the IP address you want to dial, make sure you select H323 as protocol.
Also the dialed IP address should be reachable.
Sagar
Hi Zhomart
It simply.
Configuration > System Configuration
Conference> DefaultCall>Protocol>H323
H323>Call Setup Mode> Direct
Then dial ip address :-)
br oleksandr
sagsheth
Hi Zhomart,
Sagar
Hi Zhomart
It simply.
br oleksandr
Zhomart Asken
Thanks for your fast responce!
