08-01-2012 12:57 AM - edited 03-17-2019 11:33 PM
after update the VCS to V7.1 and the TMS to 13.2 i got this error (The VCS is running in a legacy TMS Agent mode) problem on VCS)
how can i solve it
08-01-2012 01:01 AM
08-01-2012 01:04 AM
You need to switch to using TMS Provisioning Extension - there is a software package to install on TMS and then some configuration to do.
The is a white paper about the benefits here -
08-01-2012 01:39 AM
Hi Mohamed!
For now TMS and VCS will work fine with the old style of provisioning. TMSPE is the new way,
which has its advantages but also disadvantages, so I would not blind change to it without
knowing the impact.
You find more discussions and info about that in the forum.
Do not be worried.
You can just acknowledge it (it will pop up as new on every reboot).
That's not a critical issue rather then an information.
08-01-2012 03:41 AM
VCS raise this warning message for reminder to start working/investigating the TMS Provisioning Extension upgrade.
Therefore are no service impact because of this warning message and no immediate action requirement.
However Cisco highly recommends migrating provisioning feature to TMS-PE.
Data management/replication method and service robustness has improved with TMS-PE.
08-01-2012 03:51 AM
Hi Tomonori!
And I would highly recommend to add missing features to the TMSPE and make it more admin friendly :-)
Martin
