04-20-2016 03:54 AM - edited 03-18-2019 05:50 AM
Hi Guys i need help in desperate situation , my problem is i am not able to forward calls to client cell phone , This is not it goes when someoen calls on clients E.164 number the call does not forward to cell phone at at it gives fast busy tone where as if someone calls internally to that extension the call forwards successfully to cell phone i tried every thing assistance would be appreciated
04-20-2016 04:08 AM
Whenever you re-direct calls externally you have to also include any translation patterns your system has. So if to call out externally as normal you would press 9 (or whatever patten is implemented), and then type the normal number, you would also have to include the 9 in any re-directs.
04-20-2016 04:11 AM
Thanks for your response but , but my problem is something else
04-20-2016 08:04 AM
This is the Video Over IP community, you might want to move this to IP Telephony or some other community.
Also mention what troubleshooting have you done so far?
04-22-2016 04:23 PM
is this on cucm or cme?
have you got relevant trace debugs for the said call/
wht is the value set for 'Block OffNet To OffNet Transfer' in case of cucm.
can you directly reach to that pstn number from the internal phone (where forwarding is configured).
also check if there is any css/partition assigned on the forwarding number which might not be the same as in the RP/GWY
