interactive digital board integration (Cisco TelePresence Synch)End of sale
renji joy
Hello Team,
We are trying to integrate Interactive White Boards with Cisco Telepresence endpoints ,and found that Cisco TelePresence Synch(CTS-SYNCH-WBD) but currently the product is end of sale .also there is no other replacement model is getting,
Anyone can suggest the replacement model or any third party product for the interactive digital board integration.
Thanks in Advance.
8 Replies 8
Patrick Sparkman
Cisco TelePresence Synch is no longer for sale under Cisco, but instead being sold under Avizia.  If you look at the bottom of the EOS announcement under Product Migration Options it says:
Customers may be able to purchase similar products, excluding the Cisco TelePresence VX Clinical Assistant, from Cisco Solutions Technology Integrator Partners, like Avizia. For more information, go to: http://www.aviziatech.com or contact Avizia at info@aviziatech.com.
TheTelePresence Synch is not absolutely necessary device for integrate VideoEndPoint with SmartBoard.
You can use two displays (one SmartBoard, and second for the main video). Dual Display Option must be present on your VideoEndPoint.
TheTelePresence Synch  is necessary when you have only single screen(smartboard) and  want use two video streams, and want change screen layout.
br Oleksandr
Thanks for the replay,
Can you please suggest the Dual display end points ,which we can use one screen smart board ?
Thanks in advance
I need more information ...
Maybe you need two cameras? One for lector and one for room?
Maybe you need a big zoom for the camera?
Mayby you need tracking camera ?
Where and how will use the microphone?
Where do you want call? That other side should see?
Dual Display option is available in almost all Cisco video endpoints: SX20, SX80, C40/60/90 and also  EX90
br Oleksandr
Hello ,
Please find the below answers,
Yes we have required two camera
we are looking for the Live E class setup
May by you need tracking camera ?
Yes we have required,
celling or table
internal setup only,ither side should see the smart board with teacher writing.
Thanks  in advance
What is your purpose?
How do you want to use video-endpoint?
Video endpoint usually used to communicate with other far-end videoendpoint.
I think local use is not good idea .
br Oleksandr
We trying to deploy the Live E-class setup,with around 30 remote class room and one main class room,can you please suggest the good solution for the same.
Thanks in Advance.
Hello ,
celling or table
Thanks  in advance
