Is CUCM 8.6.1 compatible with Telepresence MX300 G2
david.shimp
Is CUCM 8.6.1 compatible with Telepresence MX300 G2? Everything I have found when searching references 8.6.2. My MX300 is running TC7.3.5.
I have installed cmterm-s52011tcnc7_3_5.k3.cop.sgn on my call manager. There is not an option for the MX300 after restarting it. Is that the right file? Or do I need to install the device pack also?
Jaime Valencia
http://docwiki.cisco.com/wiki/CUCM_FAQ#Adding_support_for_new_endpoints
If the docs says 8.6(2) is required, that's what you need, no way around that
java
if this helps, please rate
