03-20-2015 04:31 AM - edited 03-18-2019 04:13 AM
Hi there,
I have a couple of questions about the ISDN Link:
The scenario should be: two rooms, one equipped with a SX20 and one with an SX10; both should go in ISDN via the ISDN Link, obviously not at the same time.
Thanks in advance for your reply
Paolo
Solved! Go to Solution.
03-20-2015 04:45 AM
1) Isdn link cannot be paired with SX10
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=sx10%20isdn%20link
2) You can use the ISDN link with as many supported devices as you`d like, but only one at the time. You cannot have a C60 and EX90 at the same time
You can pair it over LAN.
If you want more than one device you would need a ISDN Gateway
//Marius
03-20-2015 04:45 AM
//Marius
03-20-2015 06:59 AM
Hi Marius,
thanks a lot for your reply.
Paolo
