Issue integration TMS with Lotus Notes
Mario Acevedo
I need integrate tms with Lotus Notes, we install tmsxn on notes, but the issue is the following:
When i booked a conference in TMS, i see it in Notes, but if i booked in Notes, doesn't appear in TMS-->List Conference.
I have TMS 13.2.
Thank you all.
Sorry for the delay,
Thank you for your help, i solved the problem restarting the Lotus Server.
Magnus Ohm
Hi Mario
Are you sure all the steps in the installation guide was followed 100%?
http://www.cisco.com/en/US/docs/telepresence/infrastructure/tmsxn/install_guide/Cisco_TMSXN_install_getting_started_guide_11-3-1.pdf
It could be permission related, please verify the troubelshooting section in the above document. If you still have an issue I recommend you to open a TAC case for further troubleshooting as log files would be required.
/Magnus
Hi Magnus, thank you for reply.
I follow all steps in the installation guide, but the issue still has not been solved.
Magnus,
Can you please provide the URL(one step up) so I can check other documents related to TMSXN for Notes or the latest version of the document.  thanks
