IX5000 Echo cancellation disable
wnsdlf1017
Frequent Visitor
Frequent Visitor
Hi everyone
I tried to turn off echo cancellation from cli.
Set audio aec disable
But, no valid command  <-this message.
Do I have to open a TAC case?
Is there other way I can turn off the echo cancellation? ??
Thank you for reading
Manish Gogna
Can you check if the Echo cancellation is turned ON:
xConfiguration Audio Input Microphone X EchoControl Mode: On (X refers to the Microphone in use i.e 1,2,3,4)
Manish
Hi Manish,
i opened a TAC for this issue and the TAC engineer said there is no command to change the Echo cancellation, even TAC engineer can not change it.
thank you,
have a great day.
