02-14-2013 07:01 AM - edited 03-18-2019 12:35 AM
We have Jabber Video for TelePresence version 4.5 installed, and it's working great overall. However, when someone using the software calls another person, either using the software or in a TelePresence room, the pop-up showing the calling party will show their Active Directory account name, rather than their "Display Name" or "First/Last" name as setup in TMS. E.g., when John Smith calls, instead of it saying "Call from John Smith," it will say "Call from josm345." I'm hoping to find a way to where it will actually say his name, but as yet have been unable. Thanks for your help!
02-14-2013 07:08 AM
Hi Jesse,
Which version of VCs software is running here?
There is a known bug (CSCua49125) solved in x7.2.1, with displayed omitted on the in the P-asserted identity on the VCS.
You might be hitting that.
Cheers
/karim
02-14-2013 07:33 AM
Thank you Karim! The VCS is currently on X7.2, so I'm going to schedule for the software upgrade and see if that fixes it. I'll update when I get it done.
