08-21-2012 12:36 AM - edited 03-17-2019 11:38 PM
I have installed a VCS Starter Pack Express with 3 SX20, 1 MCU and some Jabber Video (Movi) clients.
I have configured the system to use TCP/SIP 5060 for comunication.
I started using Jabber video version 4.4.3 and my problem is that the client is always losing connection.The client disconnects normally after 1 to 10 minutes. Even during a Video call, the client disconnects.
I already have installed Jabber Video in 7 diferent PC's (With XP and 7) and the behaviour is the same,
Inside the network, no firewall is in the way between Jabber and the VCS. I also have tested Jabber throug the Internet, in this case passing ASA firewall and the result is the same.
I have downgradded to 4.3.12 and the behaviour is the same. Only with version 4.2.0, the Jabber Video (Movi) stays connected normally. With this version stays connected more than 24H.
The VCS version was upgraded from 7.1 to 7.2 and same conclusion. Only with 4.2 version is working.
Best Regards
Paulo Rio
09-12-2012 12:20 PM
check this
CSCtz33499 : JV closes TCP connection with SIP server after receiving presence NOTIFY
Symptoms
Jabber Video for TelePresence 4.4 and 4.3 occasionally lose their registration to Cisco VCS
Conditions
Exact conditions are unknown. When this defect has occurred, the following configurations were present:
-Cisco VCS did not have TLS enabled
-Jabber Video was provisioned with "Encryption Policy" set to "Auto"
Workaround
Two workarounds are available:
-Enable TLS on the VCS, OR:
-Provision Jabber Video with Encryption Policy = ForceTcpNoSrtp instead of Auto
09-13-2012 02:26 AM
I had to open a TAC case so this could be identified. After changing Encryption Policy = ForceTcpNoSrtp, the Jabber was working fine.
