LDAP in Cisco Meeting Server
CatsAndIT
Hello!
Possibly a dumb question because we're finding the wording a bit ambiguous.
Is it possible to setup LDAP solely for the configuration/administration of the CMS2000? From the wording of the documentation, it sounds like configuring LDAP is more for allowing users to have spaces and join conferences, but I just wanted to make sure before we tried to implement it, as if we can't use it for better admin account management it doesn't serve much of a purpose for us.
Thank you!
Jaime Valencia
Yes, it's really meant for users, so you can properly associate the PMP licenses for them, not so much for admin users provisioning, and in the long run, you will be using CMM for the admin tasks.
java
if this helps, please rate
