CAB-DV10-8M+ specs
Ahmad T.
is there anything special in this ethernet cable (CAB-DV10-8M+) that should come with SKU (CS-KITPLUS-K9) ?
like if we used any cross CAT6 cable instead of this cable, will it work? or it has a specif pin arrangements in its RJ45 connectors?
you can use normal cat 6 patch code it will work .
Response Signature
