License migrating Cisco Meeting Server Edge to webrtc proxy on VCS-Expressway
jlcembellin
We are going to migrate from a cisco meeting server edge deployment to webrtc proxy on VCS expressway.
There is an existing VCS expressway with 10 traversal calls and turn license. What kind of license do wee need on VCS-E? Is a traversal license per webrtc call?
Usually you would use the Cisco Expressway product for this rather than the VCS-Expressway.  Some of the licence consumption issues will also depend on the software versions you are using (ie X12.5.1 and higher will do things differently from the old X8.x software versions).  So depending on what product and versions you use, the answers to your question may be different.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Is pair of VCS-C, VCS-E version 8.10.
