02-09-2015 04:28 AM - edited 03-18-2019 03:59 AM
Hi, fellow engineers. I have a couple question about Telepresence design. If I need to add Jabber Guest. What kind of licence will be required apart from Cisco Expressway Rich Media Session? How about endpoints? For instance, what kind of licence do I need to purchase so that I make a call from remote office by EX 90? I mean I want to make a call the Headquarter from Teleworker.
02-09-2015 05:57 AM
Hi Mikhail,
Jabber Guest license requirements are outlined in the following document
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/Guest/10_0/icg/JABC_BK_J0FC634A_00_jabberc-installation-and-configuration-guide/JABC_BK_J0FC634A_00_jabberc-installation-and-configuration-guide_chapter_01.html#JABC_RF_R41213D8_00
Manish
02-09-2015 06:06 AM
How about an endpoint which is outside my network?
02-09-2015 08:21 AM
Hi Mikhail,
Deployment guide provides these details.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/Guest/10_0/icg/JABC_BK_J0FC634A_00_jabberc-installation-and-configuration-guide/JABC_BK_J0FC634A_00_jabberc-installation-and-configuration-guide_chapter_010.html
Please note that in a production environment, Cisco Jabber Guest requires that your Cisco Unified Communications Manager be configured to work with Cisco Expressway.
Cisco Jabber Guest can be pointed directly to Cisco Unified Communications Manager for lab deployments only. You must configure a SIP trunk on Cisco Unified Communications Manager for this deployment. This option is best suited to a lab deployment in which the goal is to familiarize yourself with Cisco Jabber Guest without the additional overhead of configuring Expressway. However, without configuring Expressway, Cisco Jabber Guest is not supported in a production environment.
Manish
02-09-2015 06:21 AM
Do I need to implement Jabber Guest Server in my infrastructure? Or CUCM enough?
02-10-2015 11:38 AM
Hi Mikhail,
You don't need a Jabber Guest Server if you just allow the teleworkers with EX90 to use the Telepresence resources. You can add a Jabber Guest Server for user who does not have any video device but a H.264 based WebRTC.
HQ
