Logo on Tandberg Endpoints
binu.john
We have Tandberg VCS with endpoints EX 90 and Profile series which are registered with H323.
1)Can i upload my company logo as a background on the Tandberg endpoints?
2)Also like to know whether i could add company logo when the users dial into a conference using MCU,(like a welcome screen)?
3)Can i make to call the endpoints using ip address which are registered with H323?
Please advice.
John
You will have to make some changes on your endpoint , by making Call Mode as Direct , and then you should be able to dial directly.
For more clarifications, let me know I will open up a case on your behalf and will go for a troubleshooting session.
Saurabh
5 Replies 5
sauragu2
Hi John,
Yes, You can upload your company Wallpaper to the Tandberg Endpoints which should be *.png wallpaper of resolution 1920x1080.
Yes, you can also add any logo or banner in MCU , by logging into MCU and adding Banner in Conference section.
Yes, you can call to endpoints which are registered using H323 by using h323 : XX: XX : XX :XX
Hope I answer your query.
Saurabh Gupta
Thanks Saurabh,
If one endpoint is not registred with either H323 or SIP(only has an IP addrs), and other end point is registered with h323 can i make a call using IP from H323 device to the 1st device?
Saurabh
binu.john
Thanks Saurabh,
I will try this tommorow and let you know. Can i have your email?
Rgds
John
My Email Id is sauragu2@cisco.com
