12-22-2017 01:13 AM - edited 03-18-2019 01:42 PM
After swapping the normal hybrid camera cable on P40 with CAB-HDMI-PHD12XS on both ends, we lost the camera control on touch 10. Picture itself on camera is showing, only controlling of it is missing.
Is there a limitation on Cat cable length or do i need to get CAB-PHD4XS2-SPLIT to the other end?
Also what Cat cable can i use, does it has to be shielded?
We get tho error message "Camera not detected"
We have SX20 codec in use.
-DbD-
Solved! Go to Solution.
12-26-2017 10:25 PM
If you're using the cable that came with the SX20 (custom connector on one end, and a male RJ and make HDMI on the other), then you can just extend it with a standard straight through Cat6 cable and a RJ cable joiner.
If you're using a pair of the 4XS2-SPLIT cables, then you need to cross pins 3 and 6.
Please remember to mark helpful responses and to set your question as answered if appropriate.
12-26-2017 10:25 PM
