Manual intervention required to re-sync clustered conductors. Is that Normal?
Luke Sykes
Level 3
Level 3
Hi There
If one of two clustered conductors is lost on the network, the client has to manually intervene to resync them, is that normal or should it be done automatically?
Many Thanks
Luke
Patrick Sparkman
A Conductor should sync to any of it's cluster peers, I haven't noticed where ours hasn't.  However if it doesn't sync automatically, I quickly checked the Conductor API, and didn't see a force sync command.
