Maximum Longest HDMI Cable
Mahesh Kumar
What is the maximum longest HDMI cable can be used between C60 Codec to LCD panel and Camera without signal loss.
Atul Gaba
Hi Mahesh,
Check pg 17 of the following doc
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/camera/precisionhd/user_guide/precisionhd_1080p-720p_camera_user_guide.pdf
Camera Cables
HDMI cable
The HDMI cable delivered with the camera is 5 meters.
Maximum length is 15 meter with a category 2 certified good quality HDMI cable. This cable can be used with the C20, C40, C60 and C90 Codecs.
Check pg 11 of the following doc
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/articles_doc/telepresence_endpoints_knowledge_base_articles.pdf
307:What is the maximum length of the HDMI cable connecting a codec to a monitor?
The HDMI cable going from the Cisco TelePresence Codec to the monitor can be up to 15 meters/50 feet long. This requires a good quality category 2 cable. Longer extensions are  possible using HDMI/DVI extenders.
Applies to the following products:
SX10 Quick Set
SX20 Quick Set
SX80
Codec C20
Codec C40
Codec C60
Codec C90
HTH,
Atul
