Bookmark
Subscribe
1097
Maximum output API /participants in CMS
Phuong Pham
Hi all,
I want to set importance level for my participant. I have 50 participant in my room but when i GET participant ID, Postman tool only has 10 participant ID result. I was try with another API tool but the result still the same.
Do you know how to collect all participant ID?
Jaime Valencia
8.1.5 Retrieve participants in a conference GET method performed on the "/calls//participants" node. Retrieves a list of all of the participants associated with the specified call.
Parameters Type/Value Description/Notes
offset limit Number Number
An "offset" and "limit" can be supplied to retrieve active participants other than the first "page" in the notional list (see Section 4.1.2).
https://www.cisco.com/c/dam/en/us/td/docs/conferencing/ciscoMeetingServer/Reference_Guides/Version-2-3/Cisco-Meeting-Server-API-Reference-Guide-2-3.pdf
java
if this helps, please rate
Jaime Valencia
java
Thanks Valencia!
