Meeting Management LDAP Binding
stephen.wood
We had Meeting Management setup and synced it to LADP which worked, but now we getting a LDAP bind issue.
2 users have Operators access which they can still access but any new users cant.
2 users have been added into the AD group with Admin rights but cant access.
How can one access the admin potion to fix the LDAP bind if LADP is not working.
Jaime Valencia
I don't believe you can if you're already locked out of CMM, that's why the first time wizard tells you to make sure you finish it, as otherwise you'll need to re-do the whole install. Might want to reach out to your SE/AM to submit a PER on that so it's considered for future releases.
java
if this helps, please rate
Jaime Valencia
java
Thanks Jaime for the advise. I thought it would be like this, was hoping there was some trick.
