08-13-2012 07:15 AM - last edited on 03-25-2019 09:04 PM by ciscomoderator
Can somebody provide me the list of MIBS for the Tandberg MXP and the C-Series codecs?
08-13-2012 11:50 AM
Steve,
As far as I know there are no MIB files for the TelePresence products, they just use standard SNMP definitions.
Justin
08-14-2012 04:44 AM
HI Steve. This is the MXP MIB From F4 and up. (Long Cut and Paste)
TANDBERG-MIB DEFINITIONS ::= BEGIN
IMPORTS
enterprises, TimeTicks
FROM RFC1155-SMI
OBJECT-TYPE
FROM RFC-1212
DisplayString
FROM RFC1213-MIB
TRAP-TYPE
FROM RFC-1215;
tandberg OBJECT IDENTIFIER ::= { enterprises 5596 }
videoconf OBJECT IDENTIFIER ::= { tandberg 10 }
status OBJECT IDENTIFIER ::= { videoconf 3 }
callstatus OBJECT IDENTIFIER ::= { status 2 }
logging OBJECT IDENTIFIER ::= { videoconf 4 }
services OBJECT IDENTIFIER ::= { videoconf 5 }
system OBJECT IDENTIFIER ::= { videoconf 6 }
fun OBJECT IDENTIFIER ::= { videoconf 7 }
h323 OBJECT IDENTIFIER ::= { videoconf 8 }
codec OBJECT IDENTIFIER ::= { system 4 }
security OBJECT IDENTIFIER ::= { system 5 }
events OBJECT IDENTIFIER ::= { system 6 }
experimental OBJECT IDENTIFIER ::= { videoconf 8 }
-- Common parameters
callMode OBJECT-TYPE
SYNTAX DisplayString
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Call Mode = Idle, Telephone, Videophone, DuoVideo, MultiSite, ... "
::= { callstatus 1 }
callLastError OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Descriptive error message, set after a Enterprise Error Trap has been sent"
::= { callstatus 2 }
callLastErrorTime OBJECT-TYPE
SYNTAX TimeTicks
ACCESS read-only
STATUS mandatory
DESCRIPTION
"System time (since boot) when last error message was set"
::= { callstatus 3 }
callLastCauseCode OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"The cause value"
::= { callstatus 4 }
callLastCauseCodeLoc OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"The cause location"
::= { callstatus 5 }
statusStreaming OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Indicates if streaming is enabled or not. Idle or Streaming"
::= { services 2 }
statusVNC OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Indicates VNC status; idle, active, connectionfailure, toomanyattempts, authfailure, resfailure"
::= { services 3 }
telnet OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"enable/disable"
::= { services 4 }
ftp OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"enable/disable"
::= { services 5 }
http OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"enable/disable"
::= { services 6 }
h323 OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"enable/disable"
::= { services 7 }
remoteparameter OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"enable/disable"
::= { services 8 }
remotesoftware OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"enable/disable"
::= { services 9 }
snmp OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"enable/disable/read-only"
::= { services 10 }
telnetchallenge OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"enable/disable"
::= { services 11 }
telnetchallengeport OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
DESCRIPTION
"port number. 23 or 57"
::= { services 12 }
-- call information
callNumber OBJECT-TYPE
SYNTAX INTEGER (0..1024)
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Number of channels available for this unit"
::= { status 3 }
callTable OBJECT-TYPE
SYNTAX SEQUENCE OF CallEntry
ACCESS not-accessible
STATUS mandatory
DESCRIPTION
"The Channel information table"
::= { status 4 }
callEntry OBJECT-TYPE
SYNTAX CallEntry
STATUS mandatory
DESCRIPTION
"Information about each channels status, activity and usage"
INDEX { callID }
::= { callTable 1 }
CallEntry ::=
SEQUENCE {
callID
INTEGER,
callTag
DisplayString,
callRemoteSite
DisplayString,
callDirection
DisplayString,
callStatus
DisplayString,
callChannel
DisplayString,
callType
DisplayString,
callCause
DisplayString,
callDuration
TimeTicks,
callIncomingRestrict
DisplayString,
callOutgoingRestrict
DisplayString,
callAccNo
DisplayString,
callEncryption
DisplayString,
callSysUpTime
TimeTicks,
callChannelCurrent
DisplayString,
callH323PacketLossVal
INTEGER,
callH323PacketLossTot
INTEGER,
callH323PacketLossReportTime
INTEGER,
callH323PacketLossTotalPackets
INTEGER,
callH323PacketLossLostPackets
INTEGER
callID OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Channel number"
::= { callEntry 1 }
callTag OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Unique call identifier since reboot"
::= { callEntry 2 }
callRemoteSite OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Telephone number or other address of remote connection"
::= { callEntry 3 }
callDirection OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"idle, incoming, outgoing"
::= { callEntry 4 }
callStatus OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"idle,syncing,capex,unframed,speech,disconn,synced"
::= { callEntry 5 }
callChannel OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"idle,speech,h221-,bonding-,h323,unknown"
::= { callEntry 6 }
callType OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"idle,answering,calling,connected,disconnecting,disconnected"
::= { callEntry 7 }
callCause OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Cause code for failures"
::= { callEntry 8 }
callDuration OBJECT-TYPE
SYNTAX TimeTicks
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Duration of this connection"
::= { callEntry 9 }
callIncomingRestrict OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"restrict,norestrict"
::= { callEntry 10 }
callOutgoingRestrict OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
::= { callEntry 11 }
callAccNo OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"The access code entered for the call "
::= { callEntry 12 }
callEncryption OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"encryption status"
::= { callEntry 13 }
callSysUpTime OBJECT-TYPE
SYNTAX TimeTicks
ACCESS read-only
STATUS mandatory
DESCRIPTION
"system up time since reboot"
::= { callEntry 14 }
callChannelCurrent OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
::= { callEntry 15 }
callH323PacketLossVal OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
DESCRIPTION
"packet loss value the last 2 seconds H323"
::= { callEntry 16 }
callH323PacketLossTot OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
DESCRIPTION
"total packet loss value since last downspeed H323"
::= { callEntry 17 }
callH323PacketLossReportTime OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Report time in seconds"
::= { callEntry 18 }
callH323PacketLossTotalPackets OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Total number of packets sendt during last report time"
::= { callEntry 19 }
callH323PacketLossLostPackets OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Total number of packets lost during last report time"
::= { callEntry 20 }
-- start of inncoming entries
incomingNumber OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Number of entries in incomingTable"
::= { status 8 }
incomingTable OBJECT-TYPE
SYNTAX SEQUENCE OF IncomingEntry
STATUS mandatory
DESCRIPTION
"Table with information about incoming connections"
::= { status 9 }
incomingEntry OBJECT-TYPE
SYNTAX IncomingEntry
STATUS mandatory
DESCRIPTION
INDEX { callIncomingId }
::= { incomingTable 1 }
IncomingEntry ::=
SEQUENCE {
callIncomingId
INTEGER,
callIncomingAudio
DisplayString,
callIncomingVideoMode
DisplayString,
callIncomingVideoResolution
DisplayString,
callIncomingDuoResolution
DisplayString
callIncomingId OBJECT-TYPE
SYNTAX INTEGER ( 0..1024 )
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Identifier for each incoming table entry."
::= { incomingEntry 1 }
callIncomingAudio OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Incoming audio compression method"
::= { incomingEntry 2 }
callIncomingVideoMode OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Incoming video compression method"
::= { incomingEntry 3 }
callIncomingVideoResolution OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Incoming resolution for video"
::= { incomingEntry 4 }
callIncomingDuoResolution OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Incoming resolution for duovideo"
::= { incomingEntry 5 }
-- end of incoming table
-- start of outgoing entries
outgoingNumber OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Number of entries in outgoingTable"
::= { status 10 }
outgoingTable OBJECT-TYPE
SYNTAX SEQUENCE OF OutgoingEntry
STATUS mandatory
DESCRIPTION
"Table with information about outgoing connection"
::= { status 11 }
outgoingEntry OBJECT-TYPE
SYNTAX OutgoingEntry
STATUS mandatory
DESCRIPTION
"entry in outgoing information table"
INDEX { callOutgoingId }
::= { outgoingTable 1 }
OutgoingEntry ::=
SEQUENCE {
callOutgoingId
INTEGER,
callOutgoingAudio
DisplayString,
callOutgoingVideoMode
DisplayString,
callOutgoingVideoResolution
DisplayString,
callOutgoingDuoResolution
DisplayString
callOutgoingId OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Identifier for each outgoing table entry"
::= { outgoingEntry 1 }
callOutgoingAudio OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Outgoing audio compression method"
::= { outgoingEntry 2 }
callOutgoingVideoMode OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Outgoing video compression method"
::= { outgoingEntry 3 }
callOutgoingVideoResolution OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Outgoing resolution for video; qcif,cif,icif,..."
::= { outgoingEntry 4 }
callOutgoingDuoResolution OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Outgoing resolution for duovideo when enabled, qcif,cif,icif,..."
::= { outgoingEntry 5 }
-- end of outgoing entries
-- Codec descriptors definition
unitDesc OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Type of Codec, version"
::= { codec 1 }
versionId OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Codec software configuration identifier for major releases"
::= { codec 2 }
softwareType OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Software type descriptor (same as data port AT-command ati3)"
::= { codec 3 }
hardwareConfig OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Codec hardware configuration (same as data port AT-command ati6) "
::= { codec 5 }
softwareConfig OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Codec software configuration (same as data port AT-command ati7) "
::= { codec 6 }
localISDN OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"ISDN telephone number for this codec"
::= { codec 8 }
dispbox OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"User response from displaybox"
::= { codec 9 }
protect OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"protect on/off on the dataport"
::= { codec 10 }
ippass OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"password on/off on the dataport"
::= { codec 11 }
h323alias OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"displays the h323alias of the codec"
::= { codec 12 }
-- security descriptors definition
authService OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"ftp, telnet or http "
::= { security 1 }
authStatus OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"true or false "
::= { security 2 }
authAddr OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Remote IP address"
::= { security 3 }
authTime OBJECT-TYPE
SYNTAX TimeTicks
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Time in ticks since last reboot"
::= { security 4 }
-- events descriptors definition
eventService OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"ftp"
::= { events 1 }
eventAddr OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Remote IP address"
::= { events 2 }
eventTime OBJECT-TYPE
SYNTAX TimeTicks
ACCESS read-only
STATUS mandatory
DESCRIPTION
::= { events 3 }
eventDesc OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Event descriptor"
::= { events 4 }
-- h323 descriptors definition
gkaddres OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"gatekeeper address"
::= { h323 1 }
-- fun
snakeHigh OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Snake high score"
::= { fun 1 }
snakeName OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Snake high score name"
::= { fun 2 }
-- end of generic definitions
-- logging of calls
logNumber OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"The number of log entries in the logTable "
::= { logging 4 }
logTable OBJECT-TYPE
SYNTAX SEQUENCE OF LogEntry
STATUS mandatory
DESCRIPTION
"The call log information table"
::= { logging 5 }
logEntry OBJECT-TYPE
SYNTAX LogEntry
STATUS mandatory
DESCRIPTION
"A call log entry in the logTable "
INDEX { logID }
::= { logTable 1 }
LogEntry ::=
SEQUENCE {
logID
INTEGER,
logTag
DisplayString,
logRemoteSite
DisplayString,
logDirection
DisplayString,
logStatus
DisplayString,
logChannel
DisplayString,
logType
DisplayString,
logCause
DisplayString,
logDuration
TimeTicks,
logIncomingRestrict
DisplayString,
logOutgoingRestrict
DisplayString,
logAccNo
DisplayString,
logEncryption
DisplayString,
logSysUpTime
TimeTicks,
logH323PacketLossTot
INTEGER
logID OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Identifier for each log table entry"
::= { logEntry 1 }
logTag OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"Unique log identifier since reboot"
::= { logEntry 2 }
logRemoteSite OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"telephone number, H323-Alias or IP-address of remote connection"
::= { logEntry 3 }
logDirection OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
::= { logEntry 4 }
logStatus OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
::= { logEntry 5 }
logChannel OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
::= { logEntry 6 }
logType OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"idle/answering/logging/connected/disconnecting/disconnected"
::= { logEntry 7 }
logCause OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
::= { logEntry 8 }
logDuration OBJECT-TYPE
SYNTAX TimeTicks
ACCESS read-only
STATUS mandatory
DESCRIPTION
::= { logEntry 9 }
logIncomingRestrict OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"restrict, norestrict"
::= { logEntry 10 }
logOutgoingRestrict OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
::= { logEntry 11 }
logAccNo OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"The access code/account code used for the connection. 0 if nothing was
used"
::= { logEntry 12 }
logEncryption OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION
"encryption status"
::= { logEntry 13 }
logSysUpTime OBJECT-TYPE
SYNTAX TimeTicks
ACCESS read-only
STATUS mandatory
DESCRIPTION
"system up time since rebbot"
::= { logEntry 14 }
logH323PacketLossTot OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
DESCRIPTION
"total packet loss H323"
::= { logEntry 15 }
-- TRAP definitions
callModeChange TRAP-TYPE
ENTERPRISE tandberg
VARIABLES {callMode}
DESCRIPTION
"Informs of change in Call Mode, whenever a codec goes from Idle to Telephone, Videophone, MCU or similar."
::= 1
genericError TRAP-TYPE
ENTERPRISE tandberg
DESCRIPTION
"callLastError has been set with a new message, indicating some kind of Codec problem"
::= 2
lowBattery TRAP-TYPE
ENTERPRISE tandberg
DESCRIPTION
"Battery is low in the remote control"
::= 3
downSpeeding TRAP-TYPE
ENTERPRISE tandberg
DESCRIPTION
"Downspeeding, adjusting connection speed due to problem"
::= 4
startupgrade TRAP-TYPE
ENTERPRISE tandberg
DESCRIPTION
"A codec software upgrade has begun"
::= 5
finsishedupgrade TRAP-TYPE
ENTERPRISE tandberg
DESCRIPTION
"A codec software upgrade has been completed"
::= 6
dispboxtrap TRAP-TYPE
ENTERPRISE tandberg
DESCRIPTION
"When a display box (dispbox) is shown on the codec, and the user
presses a quick-key, this trap is sent to indivate the quick-key selected.
Values are 1,2,3"
::= 7
connect TRAP-TYPE
ENTERPRISE tandberg
VARIABLES {callID, callRemoteSite, callTag}
DESCRIPTION
"The call is connected"
::= 8
encryption TRAP-TYPE
ENTERPRISE tandberg
DESCRIPTION
"Encryption status changed to des"
::= 9
gatekeeperregfailure TRAP-TYPE
ENTERPRISE tandberg
VARIABLES {gkaddres}
DESCRIPTION
"Gatekeeper registration failure"
::= 10
gatekeeperregsuccess TRAP-TYPE
ENTERPRISE tandberg
DESCRIPTION
"Gatekeeper registration successs"
::= 11
disconnect TRAP-TYPE
ENTERPRISE tandberg
DESCRIPTION
"The call is disconnected"
::= 12
ipauthenticationfailure TRAP-TYPE
ENTERPRISE tandberg
VARIABLES {authService, authAddr, authTime}
DESCRIPTION
"A remote access to the codec failed. Access via telnet, ftp or http is logged"
::= 13
flowcontrol TRAP-TYPE
ENTERPRISE tandberg
VARIABLES {callID, callH323PacketLossVal, callH323PacketLossTot}
DESCRIPTION
"H323 downspeed"
::= 16
h323info TRAP-TYPE
ENTERPRISE tandberg
VARIABLES {callID, callH323PacketLossReportTime, callH323PacketLossTotalPackets, callH323PacketLossLostPackets}
DESCRIPTION
"H323 information"
::= 17
eventreport TRAP-TYPE
ENTERPRISE tandberg
VARIABLES {eventService, eventAddr, eventTime, eventDesc}
DESCRIPTION
"Report event activity (only ftp for now)"
::= 20
snakehighscore TRAP-TYPE
ENTERPRISE tandberg
DESCRIPTION
"snake high score"
::= 99
END
C-Series uses XML Feedback to provide status and only supports these OID's described in RFC1213
1.3.6.1.2.1.1.1
1.3.6.1.2.1.1.2
1.3.6.1.2.1.1.3
1.3.6.1.2.1.1.4
1.3.6.1.2.1.1.5
1.3.6.1.2.1.1.6
1.3.6.1.2.1.1.7
(sysDescr, sysObjectID, sysUpTime, sysContact, sysName, sysLocation, sysServices)
SNMP for Cisco MCU's:
TMS MIB is usually included in the TMS install but the MIB TMS uses to send traps to trap receiver.
TANDBERG-TMS-MIB DEFINITIONS ::= BEGIN
IMPORTS
MODULE-IDENTITY, OBJECT-TYPE, OBJECT-IDENTITY, NOTIFICATION-TYPE, Integer32, enterprises, IpAddress
FROM SNMPv2-SMI
sysUpTime, snmpTrapOID
FROM SNMPv2-MIB
DisplayString, TEXTUAL-CONVENTION, MacAddress
FROM SNMPv2-TC;
tandbergTMSEVENTModule MODULE-IDENTITY
LAST-UPDATED "201010131310Z"
ORGANIZATION "Tandberg Telecom AS"
CONTACT-INFO
"Postal:
Lysaker,
NORWAY"
DESCRIPTION
"The TANDBERG-TMS MIB specifies a conceptual group of observable
events and objects. These events and objects comprise the management information
necessary to effectively administrate TANDBERGS TMS videoconferencing management suite.
Copyright 2006-2010 Tandberg Telecom AS. All rights reserved. Reproduction of this
document is authorized on the condition that the foregoing copyright notice is included.
This SNMP MIB module (Specification) embodies Tandberg Telecom AS's proprietary
intellectual property. Tandberg Telecom AS retains all title and ownership in the
Specification, including any revisions.
Tandberg Telecom AS grants all interested parties a non-exclusive license to use
and distribute an unmodified copy of this Specification in connection with management
of Tandberg Telecom AS's products, and without fee, provided this copyright notice
and license appear on all copies.
This Specification is supplied 'AS IS,' and Tandberg Telecom AS makes no warranty,
either express or implied, as to the use, operation, condition, or performance of the
Specification."
REVISION "201010131310Z"
DESCRIPTION "Update copyright notice"
REVISION "201010081400Z"
DESCRIPTION "Add endpoint name and MAC address to traps."
REVISION "201001251300Z"
DESCRIPTION "Fix copyright notice"
REVISION "200910291200Z"
DESCRIPTION "Fixed some trap OIDs: 5596.110.6.1.3 added, 5596.110.6.1.8 was incorrectly labeled, and 5596.110.6.1.23 was renumbered from 5596.110.6.1.21"
REVISION "200909251200Z"
DESCRIPTION "Remove two textual description fields which were unused"
REVISION "200909221200Z"
DESCRIPTION "Fixed many syntax errors"
REVISION "200909181200Z"
DESCRIPTION "Mib updated with event 9 and 21"
REVISION "200606190000Z"
DESCRIPTION "Mib Created"
::= { tms 6 }
tms OBJECT IDENTIFIER ::= { tandberg 110 }
EventType ::= TEXTUAL-CONVENTION
STATUS current
DESCRIPTION
"Enumerated type representing an event type from TMS"
SYNTAX INTEGER {
boot(1),
linkDown(2),
linkUp(3),
lowBattery(6),
lostResponse(7),
gotResponse(8),
downspeeding(9),
authenticationFailure(18),
flowControl(21),
ipConflict(22),
userAssistanceRequested(23),
rogueSystemFound(118),
preregisteredSystemActivated(119),
systemChangedType(120),
packetLossOccurred(121)
AlertLevel ::= TEXTUAL-CONVENTION
STATUS current
DESCRIPTION
"Enumerated type representing the alert Level"
SYNTAX INTEGER {
noAlert(0),
critical(1),
major(2),
minor(3),
warning(4),
cleared(5)
IsClearingNotification ::= TEXTUAL-CONVENTION
STATUS current
DESCRIPTION
"Enumerated type representing whether trap is a clearing notification or not"
SYNTAX INTEGER {
no(0),
yes(1)
tmsMonitoring OBJECT-IDENTITY
STATUS current
DESCRIPTION "OID for tandbergTMSEVENTModule monitoring branch"
::= { tandbergTMSEVENTModule 1 }
tmsTrapSystemBoot NOTIFICATION-TYPE
OBJECTS { sysUpTime, snmpTrapOID, tmsAlertLevel, tmsEventTypeId, tmsSystemId, tmsSystemIpadress, tmsIsClearingNotification, tmsSystemMacAddress, tmsSystemName}
STATUS current
DESCRIPTION
"Notification that system has just booted"
::= { tmsMonitoring 1 }
tmsTrapLinkUpDown NOTIFICATION-TYPE
STATUS current
DESCRIPTION
"Notification that system has just has a LinkUp/LinkDown event"
::= { tmsMonitoring 3 }
tmsTrapLostOrGotResponse NOTIFICATION-TYPE
STATUS current
DESCRIPTION
"Notification that TMS has lost or regained connection with system. tmsIsClearingNotification = 1 if got response 0 if lost"
::= { tmsMonitoring 7 }
tmsTrapLowBattery NOTIFICATION-TYPE
STATUS current
DESCRIPTION
"Notification that a system is reporting low battery"
::= { tmsMonitoring 8 }
tmsTrapDownspeeding NOTIFICATION-TYPE
STATUS current
DESCRIPTION
"Notification that system is downspeeding"
::= { tmsMonitoring 9 }
tmsTrapAuthenticationFailure NOTIFICATION-TYPE
STATUS current
DESCRIPTION
"A failed attempt to log in on system has occurred"
::= { tmsMonitoring 20 }
tmsTrapFlowControl NOTIFICATION-TYPE
STATUS current
DESCRIPTION
"Notification that system is experiencing flow control"
::= { tmsMonitoring 23 }
tmsTrapIpConflict NOTIFICATION-TYPE
STATUS current
DESCRIPTION
"Notification of an ipconflict on network"
::= { tmsMonitoring 24 }
tmsTrapUserAssistanceRequested NOTIFICATION-TYPE
STATUS current
DESCRIPTION
"Notification that a user has requested assistance"
::= { tmsMonitoring 25 }
tmsTrapRogueSystemFound NOTIFICATION-TYPE
STATUS current
DESCRIPTION
"Notification that a rogue system (system not registered in TMS) has been found on the network"
::= { tmsMonitoring 28 }
tmsTrapPreregisteredSystemActivated NOTIFICATION-TYPE
STATUS current
DESCRIPTION
"Notification that a preregistered system in TMS has been activated"
::= { tmsMonitoring 29 }
tmsTrapSystemChangedType NOTIFICATION-TYPE
STATUS current
DESCRIPTION
"Notification that a system registered in TMS has changed system type"
::= { tmsMonitoring 30 }
tmsTrapPacketLossOccurred NOTIFICATION-TYPE
STATUS current
DESCRIPTION
"Notification that system is experiencing problems in a conference and is dropping packets"
::= { tmsMonitoring 31 }
tmsBindingPrefix OBJECT IDENTIFIER
::= { tms 1 }
tmsEventTypeId OBJECT-TYPE
SYNTAX EventType
MAX-ACCESS read-only
STATUS current
DESCRIPTION "The type of event that was thrown"
::= { tmsBindingPrefix 1 }
tmsSystemId OBJECT-TYPE
SYNTAX Integer32
STATUS current
DESCRIPTION "System id"
::= { tmsBindingPrefix 3 }
tmsAlertLevel OBJECT-TYPE
SYNTAX AlertLevel
STATUS current
DESCRIPTION "The alert Level of the event that was thrown"
::= { tmsBindingPrefix 4 }
tmsSystemIpadress OBJECT-TYPE
SYNTAX IpAddress
STATUS current
DESCRIPTION "System ip address"
::= { tmsBindingPrefix 6 }
tmsIsClearingNotification OBJECT-TYPE
SYNTAX IsClearingNotification
STATUS current
DESCRIPTION "0 = new alert, 1 = clear old alert"
::= { tmsBindingPrefix 7 }
tmsSystemMacAddress OBJECT-TYPE
SYNTAX MacAddress
STATUS current
DESCRIPTION "System MAC address in canonical order as defined by IEEE 802.1a (least significant bit first)"
::= { tmsBindingPrefix 8 }
tmsSystemName OBJECT-TYPE
STATUS current
DESCRIPTION "Name of system in TMS"
::= { tmsBindingPrefix 9 }
END
Hope this helps.
VR
Patrick
09-21-2012 10:33 AM
Hello Patrick,
Do you have a list of the thresholds/metrics of the alerts generated by the TMS ?
Thank you
09-24-2012 06:09 AM
Hi Mahmoud - I do believe if the system traps it to TMS, TMS will then forward that information to the trap server specified under network settings page. Does that answer your question?
VR
Patrick
