Microphone phone extension cable
gurung.reuban
Are microphone extension cable same for all codecs or do they have to match to each specific codecs?
Patrick Sparkman
It is dependent on the codec and microphone, as each microphone uses a different connector and can connect to only one particular set of codecs that support that connector, take a look a the TelePresence Microphones Data Sheet.
