Miracast on Cisco Kit EQ not working
dmitryrubin823
We are having issues getting Miracast to work properly on Cisco Kit EQ units in our organization.  The function works fine on Room Bar Pro units, but when attempting to start sharing on EQ, we get a message "Something went wrong" and the device does not share to the unit.  We are using the same laptop to test both devices.  Both Cisco devices are on the same network a with identical configurations for Miracast.  Any Ideas or help will be much appreciated.
Are you running the same software version on the devices, or are possibly the EQs running a different software version?
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Yes, we are running the same stable channel version on both device, RoomOS 11.24.1.5 d18e2cd1afe.  We have tried to do this on several EQ's and Bars with the same results.
What transport mode are you using?  Have you tried changing the settings in case you are having interference from other WiFi devices?  See Configure wireless sharing with Miracast®
Wayne
Hello, we also have some tickets from our customers regarding Miracast instability (usually via Direct connection). We saw lots of forum inputs at MS and other places suspecting of some Win OS update thats affected devices that was working fine previously. We experienced some issue with other streaming devices, not only Cisco.
Did you find a solution or workaround?
