Movi AD
We currently have 300 movi users and growing and are looking to intergrate the Movi login with AD so users who are provisioned in TMS can sign into movi with their AD creds
What is needed to accomplish this and how and where in TMS do changes needed to be made...I am thinking the movi provisioning template?
Tomonori Taniguchi
The AD integration for Movi/Jabber Video authentication, please check https://supportforums.cisco.com/docs/DOC-25398 for quick overview.
Detail information including configuration can be found in deployment guide, http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Authenticating_Devices_Deployment_Guide_X7-2.pdf
Will the above apply to Novell eDirectory ?
Which method should I use for eDirectory?
Hi Mohammed,
VCS has mutliple modes of authentication. you can use the
-AD
-LDAP
in case of AD direct VCS uses kerberos connection (NTLM challenge) for challenging the endpoint if it supports NTLM
i think for Novell eDirectory you can try to use LDAP H.350 if itsupports LDAP and you can play around with that. But currently VCS supports only microsoft AD as LDAP.
rgds,
Alok
