Movi With Domain
Rishu Kumar
One of our client , dont have any DNS server in house , no Domain also and likely to use Cisco Movi
Any suggestion on TMS agent data  replication, Is possible any ways got VCS X7.1 and TMS 13.2  in place
adimchev
Hi Rishu,
I am not really sure if I understand the question correctly but are you asking if it is possible to enable TMS agent data replication witht having DNS service running at all?
if that is the case then - no, it is not going to be possible.
Andrey
Hi Andrey,
You got question right. thanks for reponse .
I tried to make one entry in Host life of TMS server
"C:\Windows\System32\Drivers\etc"
it works without domain both Movi and end points are getting registered and working fine .
Rishu
Magnus Ohm
Even if this works now its not a guarantee it will work stable (assuming you are using tms agent legacy). Using hosts files
to replace DNS service is not a good solution. I have seen custimers do this and their provisioning setup has failed horribly after some time of operation. If this is a production i would consider moving to TMSPE, tmsagent legacy is
somewhat depending on DNS.
/Magnus
Hi Magnus
Sure i will consider your suggestion .
Rishu
