MSE 8510: default SSL certificate expired
RenzKanwischer
Hello Community,
the self signed SSL certificate of our MSE8510 which was setup automatically during installation is expired. Is there a way to create a new direct on the box or is this something I have to do external and upload it?
Has anyone a short guide how to do that?
Renz
Martin Koch
Check out:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/articles/mcu_certify_https_connections_157.shtml
Its always a good idea to browse the cisco documentation site first! :-)
You find also some info when you use google, like:
http://blog.codesalot.com/2010/11/25/creating-certificates-fo-codian-mcu/
Please remember to rate helpful responses (using the stars below) and mark helpful or correct answers.
Martin Koch
Check out:
Thanks Martin,
this is the "long" way to do it. My hope was that there is a button or command available. ;-)
Two additions to the mentioned links:
- the win32 version of openssl needs a parameter "-config" which points to the config file. Default is /bin/openssl.cfg
- default expiration date is only some days later. Parameter "-days" in "openssl x509 ..." can change that
Thank you for setting the thread to anwered and sharing your additions with us +5 for you.
Please remember to rate helpful responses and identify helpful or correct answers.
