MX700 Camera error
NEUNG HWI KIM
I have deployed MX700 but there comes an error on the screen.
The error says there is a camera problem and the video has been stop.
I have re-installed all of the cables, made a factory-reset, but this issue isn't solved yet.
I will attach the capture file and please check if this is an error.
If you've done all that, and still get the message, then it is likely faulty.  I'd suggest you log a call with the TAC to get a replacement.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Wayne
Hi Wayne,
Thanks for your reply.
I was expecting if there was a same problem or bug report about it.
I'll open the TAC Case to try to solve this issue.
Thank you.
I have the same problem and how did you solve it . Can you share it , thank you.
