MX700 Monitor Control
james.procopio
Is there an easy way for end users to turn off one of the screens while using the MX700 for a presentation only.  The MX700 is used primarily for video but also for non-video meetings.   It's distracting when we are just trying to present on one screen and the background image stays on the other screen.  Just want to have one monitor active.
Patrick Sparkman
There isn't a way to turn off a single monitor, unless you put the entire system into standby which will affect both monitors.  I know the MX dual screen system can show content from two different sources, one on each screen.  I didn't see any enhancement requests, but suggest you contact your Account Manager and see if they can create one so that when a single content source is connected and presenting it shows on both displays outside of a call.
