05-29-2017 04:43 AM - edited 03-18-2019 01:09 PM
Have a edge 95 with HD camera ...
Problem is I can't drive thru menus using the remote TRC4.
Camera LED blinks when pressing buttons on remote but nothing happens on the monitor menu's ??
Also the main camera not selected and no video transmit when connected in a call or audio for that matter.
Plus when remoted in via browser I select the main camera input source on the webpage but no video being transmitted.
Any ideas please.
Swapped out remote and checked the camera cable and re-connected camera cable. it's a factory cable for mxp3000 which is correct.
any other ideas please .
VR
Chet
Solved! Go to Solution.
05-29-2017 07:37 AM
I would suggest two things.
05-29-2017 07:37 AM
05-29-2017 06:50 PM
Does your MXP95 detect that a camera is connected>
What is the output of an "xStatus Camera 1" command?
You should see something like this:
*s Camera 1 (connected=True):
Type: PrecisionHD
SoftwareID: "S01692-3.0Final [ID:30038] 2009-08-27"
Pan: 408
Tilt: 43
Zoom: 12
Focus: 4246
*s/end
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
