02-15-2006 12:19 AM - edited 03-17-2019 08:38 PM
hi guys, can we set on the gateway the maximum time for a voice call?? say 15 mins? is there a way to do this without a billing server and just by using tcl scripts and radius??
02-16-2006 12:57 AM
It can be done via TCL abd via a Radius server. I would prefer using a Radius server.
Just setup some (like Cistron, FreeRadius), configure Cisco for Radius authentication on the h323, and then in the Radius server configure a Radius reply attribute "Session-Timeout" to be sent with a fixed value (15 * 60 = 900).
02-16-2006 01:22 AM
hi theodore..
thanks for the reply .will the session-timeout be applicable if i'm using app_clid_authen_collect.tcl from cisco tclware?? i also have ACS doing the radius...
by the way i'm trying to authenticate my incoming voip call before i send the call to outgoing pstn.. basically what i did on my as5400 was
application
service test flash:app_clid_authen_collect.tcl
and, on my dial-peer....
dial-peer voice 1 pots
trunkgroup 1001
description ***OUTGOING TO PSTN****
voice cut-through alert
destination-pattern .T
incoming called-number .
forward-digits all
no register e164
dial-peer voice 10 voip
service test
description ***INCOMING VOIP***
voice-class codec 1
session protocol sipv2
session target sip-server
dtmf-relay h245-alphanumeric
is this the right way to implement this??
Sincerly,
j.bien
02-16-2006 03:38 AM
Yes, the "Session-Timeout" attribute will be applicable.
You have to configure though Radius AAA authentication for the H323 services.
I think, you have to remove the "incoming called-number" from the pots dial-peer.
Turn your Radius debug to see the attributes exchange between ACS and the voice gateway.
02-16-2006 10:24 PM
thanks for these information... 'twas a great help...Cheers.
