10-11-2018 01:15 AM - edited 03-18-2019 02:24 PM
We have two C40 codecs with PrecisionHD 1080p 12X cameras. Problem is that cameras don't send video signal, but we can control them. Cameras runs on latest available firmware. Codec was upgraded several times to different TC7.x versions.
Under the Diagnostics we have two errors:
1. No input video signal on selected input connector HDMI 1.
2. Camera with id 1 has reported to have a hardware fault: Image sensor failure detected.
Can anything be done about this or cameras are dead?
Camera status:
*s Camera 1 Capabilities Options: "ptzf"
*s Camera 1 Connected: True
*s Camera 1 DownloadProgress: 0
*s Camera 1 Flip: "Off"
*s Camera 1 HardwareID: "50000000"
*s Camera 1 IpAddress: ""
*s Camera 1 MacAddress: "D8:67:D9:74:C0:EC"
*s Camera 1 Manufacturer: "Cisco"
*s Camera 1 Model: "PrecisionHD 1080p 12X"
*s Camera 1 Position Focus: 4576
*s Camera 1 Position Pan: 448
*s Camera 1 Position Tilt: 153
*s Camera 1 Position Zoom: 0
*s Camera 1 SerialNumber: "A1AB20F01131"
*s Camera 1 SoftwareID: "S01718-4.0FINAL [ID:40085] 2016-06-07"
*s Camera 1 UpgradeStatus: None
Solved! Go to Solution.
10-14-2018 06:45 PM
With an Image Sensor Failure, the camera is dead and you will need to purchase a replacement, or have it replaced via an RMA with the TAC.
Please remember to mark helpful responses and to set your question as answered if appropriate.
10-14-2018 06:45 PM
