No outgoing SI calls from ISDN
richard
Evnin'
I have setup a small lab with a 2801, PVDM2-16 and a VIC2-2BRI-NT/TE card where an ISDN phone is attached...
Calls from the Asterisk server work fine towards the ISDN phone....but when calling the other side I see in the logs:
*Sep 24 15:50:02.383: ISDN BR0/3/0 Q931: SETUP pd = 8  callref = 0x01
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Calling Party Number i = 0x0080, '1999'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x81, '995'
                Plan:ISDN, Type:Unknown
        High Layer Compat i = 0x9181
*Sep 24 15:50:02.383: ISDN BR0/3/0 Q921: Net TX -> RR sapi=0 tei=64 nr=1
*Sep 24 15:50:02.383: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=1999, Called Number=995, Voice-Interface=0x64C46B8C,
   Timeout=FALSE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=1
   Calling Number=1999, Called Number=995, Voice-Interface=0x0,
   Peer Info Type=DIALPEER_INFO_FAX
*Sep 24 15:50:02.387: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=NO_MATCH(-1) After All Match Rules Attempt
*Sep 24 15:50:02.387: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=995, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=995
   Result=Success(0) after DP_MATCH_DEST
*Sep 24 15:50:02.387: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=995
*Sep 24 15:50:02.387: ISDN BR0/3/0 Error: Invalid DSL (0)  SERROR: isdn_get_name_from_gtd: false ret
*Sep 24 15:50:02.391: ISDN BR0/3/0 Q921: Net TX -> INFO sapi=0 tei=64, ns=0 nr=1
*Sep 24 15:50:02.391: ISDN BR0/3/0 Q931: SETUP_ACK pd = 8  callref = 0x81
        Channel ID i = 0x89
*Sep 24 15:50:02.399: //-1/63B5EB1F8013/DPM/dpMatchPeersCore:
*Sep 24 15:50:02.399: //-1/63B5EB1F8013/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
*Sep 24 15:50:02.407: ISDN BR0/3/0 Error: Invalid DSL (0)  SERROR: isdn_get_name_from_gtd: false ret
*Sep 24 15:50:02.423: ISDN BR0/3/0 Q921: Net RX <- RR sapi=0 tei=64 nr=1
*Sep 24 15:50:02.423: ISDN BR0/3/0 Q921: Net TX -> INFO sapi=0 tei=64, ns=1 nr=1
*Sep 24 15:50:02.423: ISDN BR0/3/0 Q931: CALL_PROC pd = 8  callref = 0x81
*Sep 24 15:50:02.463: ISDN BR0/3/0 Q921: Net RX <- RR sapi=0 tei=64 nr=2
*Sep 24 15:50:02.911: ISDN BR0/3/0 Q921: Net TX -> INFO sapi=0 tei=64, ns=2 nr=1
*Sep 24 15:50:02.911: ISDN BR0/3/0 Q931: DISCONNECT pd = 8  callref = 0x81
        Cause i = 0x82A6 - Network out of order
So as soon I dial (995 is on the Asterisk, 1999 the ISDN phone on the 2801) I get a busy tone...
When the 2801 is idle...I still see the dial logs:
*Sep 24 15:53:48.543: //-1/EA833159810F/DPM/dpAssociateIncomingPeerCore:
   Calling Number=asterisk, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
*Sep 24 15:54:48.559: //-1/0E484BD18110/DPM/dpAssociateIncomingPeerCore:
*Sep 24 15:55:48.571: //-1/320E03098111/DPM/dpAssociateIncomingPeerCore:
0 Replies 0
