09-24-2020 04:34 AM
the One Button to Push with Office 365 using Webex Hybrid Calendar integration documentation mention to use "Room Mailbox" that is a type o Shared Resource on O365. Equipment Mailbox is also a Shared Resource.
Does anyone know if is it supported to use "Equipment Mailbox" instead of Room Mailbox in this kind of integration?
Thanks in advanced.
Solved! Go to Solution.
09-24-2020 10:16 AM
I have openned a support case and the answer was no.
It may work but its not supported in case of future issues.
09-24-2020 10:16 AM
