Partial display of custom zoom button on Room
Jsam
Recently ran into this issue where an existing custom action button/macro (zoom action panel where you put in the digits for the meeting) on an Room kit, is now only partially showing on the Touch10 (the bottom portion of the button/panel gets cut off).  Any idea how to troubleshoot ?  I did a basic side-by-side comparison of a different Room Kit system and the only difference I can see is that this system was registered to Control Hub vie Edge for Devices.  Same OS, same macro running, no other issues.
I disabled that webexEdge setting and rebooted, but no luck.
0 Replies 0
