09-07-2020 12:24 AM
After participants join the CMS conference meeting I cannot see them on the CMM. It takes more than 1 minute before I see their connection status on CMM. I have two systems but only one has the problem. Both systems are running on the same software version. I reboot the CMM and CMS but have same problem.
Please help.
Solved! Go to Solution.
09-24-2020 02:59 AM
It sounds like a network issue of the cdr procedure between CMS and CMM
Try to look on the CDR conversation from CMS by the trace log from CMS
09-17-2020 01:16 PM
Hi Simon, which CMM and CMS versions you are running on ? I have 2.9.1 for both and there is no issue.
09-24-2020 02:59 AM
