ā04-03-2017 06:11 AM - edited ā03-18-2019 12:57 PM
Dear Experts,
Is there any way to associate specific users with PMP licenses.
I have 1000 users in my AD and I want to associate these 25 licenses to specific users without changing anything in AD, I don't want to create separate OU for these 25 users.
ā04-03-2017 07:44 AM
For anyone that you want to assign a PMP license to, you will need to have those users within their own AD group, it's not possible to specify which users within a group will get a PMP license.
ā04-03-2017 09:33 AM
So you mean to say if I have different users from different groups I cannot associate, For them,
This is very bad man how we will make customers agree to change the AD configuration
ā04-03-2017 10:02 AM
Correct, Conductor will raise an alarm when the number of PMP license owners exceeds the number of installed PMP licenses.
ā04-03-2017 10:16 AM
You do not need to create a new OU necessarily. As long as all the users required currently belong to the same OU (even if they're not the only members), then you can use an LDAP filter to get only the users you want. There are many possible filters, and the right one will depend how users are currently setup, and other variables. There are many online resources on how to setup LDAP filters, as well as the CMS Deployment Guides. The simplest is usually to make the CMS users part of the same Group, and filter on that.
ā04-03-2017 10:56 AM
You can create a group within TMSPE that identifies your PMP users, and use LDAP filters to import users allowed to have a PMP license. The filter could be based on an identifier within their AD profile, or it could import users that are a member of a specific AD group that contains only your PMP users.
My comments above were based on just that:
One thing to note, that on any other group, you will need to make sure you omit any PMP user that is a member of the AD security group that you're importing. If you do not and the user is a member of more than one TMSPE group, that user will then start to be moved from group to group when TMSPE syncs the groups with AD.
ā04-03-2017 11:49 AM
Anthony, i am agreed with your points we can use LDAP filters. How we will do filtering if I want to use random users from my AD-like directors, Managers, IT Admins and so on.
is there any solution for this ???
cisco should put some option in TMSPE inside to associate PMP licenses with a specific user.
