PrecisionHD USB with Codec C40
we bought PrecisionHD USB #CTS-PHD-CAM-USB= to connect to Telepresence Codec C40, does any one know how to make this work?
Richard Bayes
That Camera is meant for use with a Windows PC and a Jabber Style client.
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/telepresence-precisionhd-usb-cameras/data_sheet_c78-628611.html
You would need to purchase one of the PrecisionHD 720p/1080p Cameras
http://www.cisco.com/c/en/us/products/collaboration-endpoints/telepresence-precisionhd-cameras/index.html
which is designed to work with the TelePresence codecs (C Series and SX20)
Thanks for your reply, but do you think if we use a USB to HDMI converter to connect the USB camera to the HDMI input will work?
I doubt it. Those converters are designed to take a USB signal from a PC and convert it to HDMI, but the USB camera is depending on the USB connection for power, which I'm pretty sure would not get supplied in this case.
