QoS 2960 MQC
Alex Pfeil
Level 7
Level 7
I have a Cisco 2960 switch with a video conferencing unit connected.  For testing purposes, I setup an access-list, class-map, and policy-map and applied it to the incoming port to change the DSCP value of the packets.  The policy-map on the interface shows all 0s.  Should this work and is the output of the command normal? Can I only mark the dscp value on an outgoing trunk interface?
int fa0/0
service-policy input MARK-ME
ip access-list extended VIDEO
10 permit ip any any
class-map VIDEO
match access-group name VIDEO
policy-map MARK-ME
class VIDEO
set dscp cs5
  Service-policy input: MARK-ME
    Class-map: VIDEO (match-any)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: access-group name VIDEO
        0 packets, 0 bytes
        5 minute rate 0 bps
    Class-map: class-default (match-any)
      0 packets, 0 bytes
      Match: any
        0 packets, 0 bytes
Thanks in advance!
Alex
Terry Cheema
The values are showing as 0 as the queuing for switches would be done in hardware so the counters do not increment so this is normal.
As long as your ACLs are matching traffic you should be able to classify and mark the traffic.
There's a documented defect for this:
Ref: https://tools.cisco.com/bugsearch/bug/CSCso80701
"show policy-map interface" in 2960, 2970, 3560, 3750 should give error
CSCso80701
Symptom:
"show policy-map interface" shows no matches
Conditions:
This command is run on one of the following switches:
2950
2960
2970
3550
3560
3750
Workaround:
This is a hardware limitation and these switches do not support this output.
However, the following show command can be used as a workaround:
"show mls qos interface
-Terry
Please rate all helpful posts and mark the thread as answered if you have no other queries.
