11-24-2011 04:05 AM - edited 03-17-2019 10:38 PM
Hi all ,
In the branch we have VoIP Server ( open source ) connected to our Cisco Router 7200 ,
I build class map based on ACL contains the IP range of our SIP phones with codec G711
then I put it inside policy map and give it priority 25% , the total BW is 2M E1 then I applied it to the output serial interface in the router ?
in one moment we have around 5 callsor less to the other branch , but unfortunatly the settings sometimes not working and we get bad quality in the calls !!
what is worng on my setup ? and do I need to ask the other branch to do the same thing or QoS in one end is fair enogh to guarantee good calls between the two branches ?
regards
11-26-2011 09:59 PM
is it difficult to answer this question ?
11-27-2011 07:43 AM
The requirements for voice are the same in both directions - same bandwith, same jitter/latency requirements.
As such you need to configure it on both ends of the link.
If the link is not a simple, direct, point-to-point link (e.g. it's actually MPLS or whatever) you would also need to engage with your service provider to ensure traffic is correctly prioritised through their network.
Have you also verified traffic is being prioritised with 'show policy-map interface xxx'?
Aaron
Please rate helpful posts..
11-29-2011 10:30 AM
thnx dear for your response ,
in regards of " show policy-map int XX " command i tested it but no thing is match !!!!
the ip phone has IP 192.168.1.240 and the ACL I used tp apply in class map is
deny ip 192.168.1.255
permit 192.168.1.240 0.0.0.15
deny ip any
assuming the IP range 192.168.1.240 - 192.168.1.254 will be reserved for IP phone ...
but no match in the ACL , why ?
regards ,
