Quad Cam mikes not working with Codec Pro
WillyT
I've installed a Codec Pro with quad cam and PTZ. I cant get mikes to work on Quad cam. Audio out from quad cam is working
the microphones in the quad cam unit are only there for audio triangulation for Speacker/Presenter Track feature You should use   plugged in microphones to the codec you are using E.G Room Kit Plus or Pro.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Carlo
