Question about CTS-MIC-CLNG-G2 Ceiling Mic mounting clips
I've been reading over the data sheet and installation instructions for the CTS-MIC-CLNG-G2 ceiling microphones.  It says that ceiling mounting clips aren't included, but I can't find any info on where to get them?
The old ceiling microphones came with generic ceiling mounts for a standard grid pattern ceiling.  Is this something I would need to source from a third party in this instance?
Patrick Sparkman
Looking at the install guides of the old Audio Science Ceiling Microphone vs the Cisco TelePresence Ceiling Microphone, it says the ceiling mounts aren't included.  It does however provide the ceiling grommets, if you choose to mount it to the ceiling tile itself instead of the ceiling track.
If you do a google search for "Ceiling track clip 4G16" and "Ceiling track clip 4J15" from the audio science install guide, parts B and C, you might be able to get them from a third party.
Patrick Sparkman
