09-22-2013 04:26 PM - edited 03-18-2019 01:51 AM
Does anybody know if the EX90's PC port speed/duplex settings follow the settings for the primary port, or does it always stay at Auto?
Is there a way to manually set it?
As we utilise fibre in many locations, hard setting speed and duplex settings is unfortunately a neccesity in many cases.
09-25-2013 08:04 PM
The EX90 acts as a switch, so the two ports operate separately. I cannot see a way via the interface to set the PC port settings and it stays as auto. This port can negotiate a different speed than then LAN/primary port.
As long as the LAN/primary port has the right speed and duplex setting to connect to your network, the connection to the PC shouldn't be a problem.
Please remember to mark helpful responses and to set your question as answered if appropriate.
09-25-2013 09:02 PM
Thanks Wayne.
Unfortunately, it's still a problem... we are running a fleet of thin clients over fibre SFP > media converter. The thin client speed/duplex settings are assigned according to which subnet they sit in. As 95% of our fleet plugs straight into the media converter, they are hard set to 100Mbps/full duplex. Essentially this means that we need to set up a different subnet and VLAN, with different speed/duplex settings, for thin clients that sit behind an EX90.
It seems a bit silly that you could set speed/duplex on one port and not the other, especilly when the device is made by a networking company
09-25-2013 11:30 PM
You can probably change the setting on the NIC via a root login with the ethtool command, but not sure how you'd get that to stay there as a persistent setting (and it's not likely to be a "Supported" fix).
Perhaps the best path for you would be to log the ability to enable this functionality as a Feature Request with your Cisco Account Manager and hope that R&D include it in a future firmware release.
Please remember to rate replies and mark question(s) as "answered" if applicable.
