question about system task $restart
jixiang_89
Hi all,
    I  am trying to use the system task $restart recently and hit some questions.
    My application communicates with other process by socket which is implemented by PLI. The question is that after I invoke $restart() on verilog side, the socket connection between simv and other process  will be broke.
And I saw some message like below:
Detaching after fork from child process 27467.
Executing new program: /home/***/sys
Notice: sys is equal to simv.
Does it hint that $restart start a new process? Could you give me some suggestions?
Thanks.
Dan Lukes
Wrong forum - Feedback Forum is dedicated to non-technical questions. See description for details.
What product/service/feature you are speaking about ?
Thanks first,
    There are too many forms for me to choice, do you know which one I should focus on?
    I'm using vcs now.
As vcs stand for Cisco TelePresence Video Communication Server the TelePresence seems to be good advice. Thread has been moved here.
