Question in the CTS 500 - IP Phone Midlet configuration
Arbenjamin
Dear all,
We have upgrade the CTS-500 1.9.1, however, we have a small question in the Midlet configuration
Service URL—The Service URL should be in the following format: http://xx.xx.xx.xx:6970/TSPM.y-y-y-YY.jad where the following is true:
xx.xx.xx.xx is the IP address of the Cisco Unified CM server,
y-y-y- is the version of the MIDlet application being added to Cisco Unified CM, and
YY is the build version of the MIDlet application being added to Cisco Unified CM.
We have uploaded the TSPM-1.9.1-P1-1S.jar and TSPM-1.9.1-P1-1S.jad, however, where can we idendify the y-y-y and YY?
Many Thanks.
Ben
Marius Nedregaard
Hi.
I am not 100% sure if I understand your question.
http://xxx.xxx.xxx.xxx:6970/TSPM-1.9.1-P1-1S.jad would be correct.
You can check that the upload is successfull by going into "TFTP File Management" under CUCM OS administrator.
//Marius
Marius Nedregaard
Hi.
//Marius
Dear Marius,
Thanks for your answer !
I am very confused on the administration giuld with the
So, I expect the format will
http://xx.xx.xx.xx:6970/TSPM.1-9-1.P1-1S.jad
Anyways, your answer is correct , we are much apprecaite  !
Best Regards,
Ben
